Marks Web Site
Date:  8-3-2009
Number of Hours:  2.50
Manual Reference:  8-x
Brief Description:  EFIS harness installation...
I went to Oshkosh for Airventure 09 and while there I picked up the EFIS wiring harness, magnetometer and OAT probe from Advanced Flight Systems for the second Display I will be installing. Today I began the component installation by running the wiring harness through the sub panel. I further routed the magnetometer cable through the fuselage to the magnetometer mount tray. I mounted the magnetometer, soldered the wires to the connector, installed the connector backshell and all the clamps supporting the wiring harness.
EFIS connector and wiring harness installation started
EFIS magnetometer and wiring installed
